Date/Time: Wed, 08 May 2024 05:39:06 +0000
change of resolution once SC open
View Count: 833
[2020-02-10 06:53:03] |
arruga - Posts: 249 |
Hi I ran SC in my laptop Then I slept my computer... plugged it to my docking to a larger screen Resolution is screwed... is there any way to re-adjust resolution with SC opened, without having to close and reopen SC? |
[2020-02-10 07:18:30] |
We do not know exactly what this means but most likely you are referring to font size settings. So in this case, follow the instructions here: Graphics Settings: Adjusting Graphics Settings and Fonts for High DPI Displays Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
