Date/Time: Mon, 29 Apr 2024 11:34:22 +0000
Get current Index value for user drawn ray
View Count: 607
[2020-02-09 11:52:25] |
User289849 - Posts: 2 |
Hello, I'm just curious if it's possible to get the current Index value of a user drawn line or ray. Sorry if I have overlooked this in my searches. Originally I looked for a simple price crossover/crossuder of a user drawn line/ray. Found nothing. Then looked for a way to get the current Index value of a user drawn line/ray. Found nothing. So I'm at the point I assume it's necessary to get the BeginValue/EndValue of the line/ray, and calculate a crossover/under myself. If there is an easier way to do this, a point in the correct direction would be appreciated. Br. |
[2020-02-10 02:56:50] |
The most that is available is just getting the drawing structure members with this function: Using Drawing Tools From an Advanced Custom Study: sc.GetUserDrawnDrawingByLineNumber() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-10 02:57:27
[2020-02-10 15:44:35] |
ok, thank you very much.
