Date/Time: Fri, 03 May 2024 14:26:22 +0000
Is Chartbook the only way?
View Count: 509
[2020-02-08 08:56:52] |
User575872 - Posts: 59 |
Hello, I have two monitors for SC, but I can't manage to place a chart on the second monitor without pulling the chartbook window over both monitors. Is this the normal way or is there another way?
[2020-02-10 11:24:48] |
Refer to: Detaching and Attaching Chart Windows Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
