Date/Time: Tue, 07 May 2024 07:48:41 +0000
Importing minute futures data
View Count: 420
[2020-02-07 20:04:37] |
User644954 - Posts: 3 |
I have a lot of 1 minute futures data that I want to import as continuous contract data. However, I don't want it to interfere with the realtime data. For example, I want to create a symbol like NQ and and import the data to that unique symbol. Is that possible? |
[2020-02-08 04:52:56] |
Yes. Just make sure you use a symbol for the data file which is not conflicting with the actual symbols used by the connected Data/Trading service.
