Date/Time: Thu, 02 May 2024 03:21:01 +0000
[Programming Help] - Simplest way to distinguish between an Up bar vs Down bar
View Count: 859
[2020-02-07 17:58:30] |
tommartin321 - Posts: 74 |
Hello, I'm currently distinguishing between an Up bar vs Down bar as shown below. I'm not concerned with doji bars. Up Bar: =E3 > B3 Down Bar: =E3 < B3 Is this the most efficient way to reference an Up vs Down bar? I was surprise I couldn't find a simple study for this. Thanks, Tom |
[2020-02-07 19:29:37] |
Sawtooth - Posts: 3989 |
Use this method: Spreadsheet Example Formulas and Usage: Formula that Matches the Coloring of Up and Down Price Bars |
[2020-02-08 17:37:43] |
Thanks Tom. I've placed the code in column T at row 3, but it only produces a 1/-1 for row 3. Shouldn't it generate a result (1, -1) for every row in column T? Thank you, Tom |
Column T.png / V - Attached On 2020-02-08 17:34:09 UTC - Size: 8.69 KB - 223 views |
[2020-02-09 00:57:35] |
Use the Sheet# that matches the chart #,or set the Formula Source Sheet Number to Sheet1. |
[2020-02-09 02:25:30] |
That was it, thank you.
