Date/Time: Fri, 03 May 2024 04:15:35 +0000
Open File
View Count: 760
[2020-02-06 16:17:26] |
Tony - Posts: 460 |
Hi, I am trying to open a text file: int TextFileHandle = 1; OpenFile("C:\\SierraChart\\Text\\t.txt", FILE_MODE_OPEN_EXISTING_FOR_SEQUENTIAL_READING, &TextFileHandle); Build Output (remote build) says: error: 'FILE_MODE_OPEN_EXISTING_FOR_SEQUENTIAL_READING' was not declared. Not sure what I did wrong, Thanks |
[2020-02-06 17:46:58] |
You need to use sc.OpenFile: sc.OpenFile() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
