Date/Time: Fri, 03 May 2024 05:36:32 +0000
Renko bar OHLC write bar data to file
View Count: 488
[2020-02-06 14:17:30] |
User719310 - Posts: 23 |
Hi, when using renko bars with the write bar and study data to file, the renko open and renko close replace the High and Lows of the OHLC and the true high and lows are not there. For example when using 28 renko bars on symbol eu6 the high on 31/02/2020 at 16:00 was at around 1.11250 but the number written to the file for the high is 1.1099. In the chart values window the current OHLC of the open bar in progress have the correct values and renko open and close are separate values. Is there a way to write the correct highs and lows from the wicks of the renko bars to the file rather than the renko open and close in their place?. Thank you |
[2020-02-06 18:22:07] |
No, unless we add an option for this. But it is not something we would be able to get to for a long time.
