Date/Time: Sat, 27 Apr 2024 15:09:20 +0000
[User Discussion] - Ask Orders
View Count: 583
[2020-02-05 13:25:56] |
Robin Wyss - Posts: 7 |
Hello, I have no value for the Ask Orders and the Bid orders. How can I set Sierra to enable this data? best regards, Robin http://www.sierrachart.com/image.php?Image=1580909089753.png |
Attachment Deleted. Capture.PNG / V - Attached On 2020-02-05 13:16:38 UTC - Size: 25.63 KB - 203 views |
[2020-02-05 18:46:02] |
Sierra_Chart Engineering - Posts: 14110 |
Those fields are not available with EUREX Data.
[2020-02-06 13:37:27] |
I used to have eurex data from marex through TT plateforme; the Ask / Bid orders is available. What type of Data eurex provide you? How can we get through this issue? best regards, Robin |
[2020-02-06 18:20:48] |
With the source we obtain the data feed from, those fields are not available. There is nothing we can do in regards to this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-06 18:20:53
[2020-02-06 19:31:47] |
Is the issue the same with the professionnal data feed? best regards, Robin |
[2020-02-06 23:53:26] |
Yes it is the same.
