Date/Time: Thu, 02 May 2024 09:27:38 +0000
Cannot connect to data feed. Message log enclosed.
View Count: 506
[2020-02-04 15:15:41] |
User727773 - Posts: 13 |
Reading Internal Order ID file. | 2020-02-04 09:33:17.165 Reading Trade Orders file. | 2020-02-04 09:33:17.315 Reading Trade Positions file. | 2020-02-04 09:33:17.316 Reading Account Balance file. | 2020-02-04 09:33:17.316 UDPListener (1032). Port 22904 | Listening on UDP port 22904. | 2020-02-04 09:33:17.339 Software version: 2040 32-bit | 2020-02-04 09:33:17.340 Usage time has ended. Sierra Chart is in Free mode. Features are restricted. | 2020-02-04 09:33:17.340 To purchase usage time, select 'Help >> Add Usage Credit' on the menu. | 2020-02-04 09:33:17.340 * Allow Support for Sierra Chart Data Feeds is enabled. | 2020-02-04 09:33:17.340 Current selected Data/Trading service: GAIN Capital/OEC | 2020-02-04 09:33:17.340 Custom symbol settings values: disabled | 2020-02-04 09:33:17.340 Chart Update Interval: 500 | 2020-02-04 09:33:17.340 Intraday Data Storage Time Unit: 1 | 2020-02-04 09:33:17.340 Time Zone: +00:00:00 (UTC+00) | 2020-02-04 09:33:17.340 2020-02-04 18:33:17 Local computer time | 2020-02-04 09:33:17.340 2020-02-04 09:33:17 Local computer time in UTC | 2020-02-04 09:33:17.340 2020-02-04 09:33:17 Local computer time in SC Time Zone | 2020-02-04 09:33:17.340 2020-02-04 09:33:15 Server time in UTC | 2020-02-04 09:33:17.340 Local computer UTC time and Server UTC time difference: 1 seconds. | 2020-02-04 09:33:17.340 Program path: C:\Program Files (x86)\SierraChart\ | 2020-02-04 09:33:17.340 Data Files path: C:\Program Files (x86)\SierraChart\Data\ | 2020-02-04 09:33:17.340 OS Version Number: 6.1 | 2020-02-04 09:33:17.341 Locale Setting: C | 2020-02-04 09:33:17.341 DLLs: amirNStuff.dll, HindsightTrading.dll, IOAMT.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2020-02-04 09:33:17.342 Checking for new symbol settings. Requested symbol settings MD5 for service code oec. Request ID: 1. | 2020-02-04 09:33:17.361 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-02-04 09:33:17.384 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-02-04 09:33:17.634 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-02-04 09:33:17.634 Received 5 login tokens. | 2020-02-04 09:33:18.210 Symbol settings MD5 received. Request ID: 1. | 2020-02-04 09:33:18.525 Requested symbol settings for service code oec. Request ID: 2. | 2020-02-04 09:33:18.525 Symbol settings received. Request ID: 2. | 2020-02-04 09:33:20.203 A request for the latest software update has been made. | 2020-02-04 09:33:21.443 * The update is being downloaded in the background. When it is complete, you will be prompted. | 2020-02-04 09:33:21.443 * Download for software update has been redirected. Request ID: 1 -> 2. New URL: https://download2.sierrachart.com/downloads/SierraChartFileDownloader.exe | 2020-02-04 09:33:22.454 Connect to Data Feed | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-02-04 09:33:23.455 * File has been written to: C:\Program Files (x86)\SierraChart\SierraChartFileDownloader.exe. File Size: 6044160 bytes. | 2020-02-04 09:33:29.671 Using SC exchange feed2. Symbol: ZC?## | 2020-02-04 09:33:48.653 ZCH20 3 Min #64 | Reloading chart. | 2020-02-04 09:33:48.653 FESXH20 #11 | Reloading chart. | 2020-02-04 09:33:48.666 VXH16 3 Min #18 | Reloading chart. | 2020-02-04 09:33:48.674 EURUSD Daily #30 | Reloading chart. | 2020-02-04 09:33:48.777 FESXH18 3 Min #36 | Reloading chart. | 2020-02-04 09:33:48.848 FESXM12 3 Min #39 | Reloading chart. | 2020-02-04 09:33:48.862 FGBLH20 3 Min #40 | Reloading chart. | 2020-02-04 09:33:48.951 Using SC exchange feed2. Symbol: GCL?## | 2020-02-04 09:33:48.971 GCLZ20 3 Min #43 | Reloading chart. | 2020-02-04 09:33:48.971 Using SC exchange feed2. Symbol: ES?## | 2020-02-04 09:33:49.047 ESH20 #46 | Reloading chart. | 2020-02-04 09:33:49.047 Using SC exchange feed2. Symbol: GGC?## | 2020-02-04 09:33:49.113 GGCJ20 3 Min #47 | Reloading chart. | 2020-02-04 09:33:49.114 USDJPY Daily #56 | Reloading chart. | 2020-02-04 09:33:49.150 ZNU06272013 Daily #61 | Reloading chart. | 2020-02-04 09:33:49.238 $VIX Daily #17 | Reloading chart. | 2020-02-04 09:33:49.252 $TYX Daily #66 | Reloading chart. | 2020-02-04 09:33:49.284 Using SC exchange feed2. Symbol: NKD?## | 2020-02-04 09:33:49.348 NKDH20 3 Min #38 | Reloading chart. | 2020-02-04 09:33:49.349 CT-MH20 5 Min #71 | Reloading chart. | 2020-02-04 09:33:49.413 KC-MH20 3 Min #35 | Reloading chart. | 2020-02-04 09:33:49.683 KCN11 Daily #75 | Reloading chart. | 2020-02-04 09:33:49.706 CCN11 Daily #55 | Reloading chart. | 2020-02-04 09:33:49.744 FGBLZ16 3 Min #12 | Reloading chart. | 2020-02-04 09:33:49.774 VXG20 3 Min #67 | Reloading chart. | 2020-02-04 09:33:49.796 TFM11 3 Min #88 | Reloading chart. | 2020-02-04 09:33:49.870 $FVX Daily #8 | Reloading chart. | 2020-02-04 09:33:49.906 Using SC exchange feed2. Symbol: ZB?## | 2020-02-04 09:33:49.927 ZBH20 #60 | Reloading chart. | 2020-02-04 09:33:49.927 Using SC exchange feed2. Symbol: GCL?## | 2020-02-04 09:33:50.059 GCLH20 3 Min #33 | Reloading chart. | 2020-02-04 09:33:50.059 FGBLU18 3 Min #79 | Reloading chart. | 2020-02-04 09:33:50.098 FGBLU15 #83 | Reloading chart. | 2020-02-04 09:33:50.185 Using SC exchange feed2. Symbol: GSI?## | 2020-02-04 09:33:50.278 GSIH20 3 Min #92 | Reloading chart. | 2020-02-04 09:33:50.278 Using SC exchange feed2. Symbol: ZC?## | 2020-02-04 09:33:50.553 ZCZ15 3 Min #96 | Reloading chart. | 2020-02-04 09:33:50.553 Using SC exchange feed2. Symbol: ES?## | 2020-02-04 09:33:50.583 ESZ18 3 Min #15 | Reloading chart. | 2020-02-04 09:33:50.583 NGN13 Daily #34 | Reloading chart. | 2020-02-04 09:33:50.738 Using SC exchange feed2. Symbol: GCL?## | 2020-02-04 09:33:50.915 GCLH20 #26 | Reloading chart. | 2020-02-04 09:33:50.915 Using SC exchange feed2. Symbol: GCL?## | 2020-02-04 09:33:51.356 GCLZ18 3 Min #7 | Reloading chart. | 2020-02-04 09:33:51.356 Using SC exchange feed2. Symbol: ZS?## | 2020-02-04 09:33:51.440 ZSH20 3 Min #101 | Reloading chart. | 2020-02-04 09:33:51.440 Using SC exchange feed2. Symbol: GNG?## | 2020-02-04 09:33:51.458 GNGX18 #98 | Reloading chart. | 2020-02-04 09:33:51.458 Using SC exchange feed2. Symbol: ZN?## | 2020-02-04 09:33:51.657 ZNH20 #70 | Reloading chart. | 2020-02-04 09:33:51.657 Using SC exchange feed2. Symbol: GGC?## | 2020-02-04 09:33:52.109 GGCQ18 #13 | Reloading chart. | 2020-02-04 09:33:52.109 Using SC exchange feed2. Symbol: NKD?## | 2020-02-04 09:33:52.150 NKDZ15 3 Min #104 | Reloading chart. | 2020-02-04 09:33:52.150 ESU3intraday 3 Min #5 | Reloading chart. | 2020-02-04 09:33:52.218 Using SC exchange feed2. Symbol: ES?## | 2020-02-04 09:33:52.253 ESM19 3 Min #4 | Reloading chart. | 2020-02-04 09:33:52.254 Using SC exchange feed2. Symbol: ES?## | 2020-02-04 09:33:52.680 ESU19 3 Min #54 | Reloading chart. | 2020-02-04 09:33:52.680 $KSIC Daily #105 | Reloading chart. | 2020-02-04 09:33:52.767 $SPX Daily #10 | Reloading chart. | 2020-02-04 09:33:52.992 SP500-I Daily #22 | Reloading chart. | 2020-02-04 09:33:53.076 Using SC exchange feed2. Symbol: ZN?## | 2020-02-04 09:33:53.702 ZNU19 3 Min #2 | Reloading chart. | 2020-02-04 09:33:53.703 Using SC exchange feed2. Symbol: ZB?## | 2020-02-04 09:33:53.826 ZBU18 3 Min #9 | Reloading chart. | 2020-02-04 09:33:53.826 $TNX Daily #24 | Reloading chart. | 2020-02-04 09:33:53.871 Using SC exchange feed2. Symbol: ZB?## | 2020-02-04 09:33:53.921 ZBM18 3 Min #27 | Reloading chart. | 2020-02-04 09:33:53.921 $TNX Daily #20 | Reloading chart. | 2020-02-04 09:33:54.628 $SPX Daily #25 | Reloading chart. | 2020-02-04 09:33:54.668 Using SC exchange feed2. Symbol: ZN?## | 2020-02-04 09:33:54.747 ZNM19 3 Min #28 | Reloading chart. | 2020-02-04 09:33:54.747 ES02142019 3 Min #1 | Reloading chart. | 2020-02-04 09:33:54.783 ZN02142019 3 Min #6 | Reloading chart. | 2020-02-04 09:33:55.383 ESH20 [CBV] Daily #14 | Reloading chart. | 2020-02-04 09:33:55.408 ESH20 [CBV] Daily #14 | Limiting the number of years to download historical data for to 0 years for the continuous futures chart. Reason: Account level limitation. | 2020-02-04 09:33:55.408 ESH20 [CBV] Daily #14 | Performing historical Daily data download for symbol ESH20 starting at last date in file. | 2020-02-04 09:33:55.409 Starting DelayedDownloadMonitoringTimer | 2020-02-04 09:33:55.409 Starting HDTimeoutTimer | 2020-02-04 09:33:55.409 Historical data service client indicated that downloads are not enabled. Symbol: ESH20. Data Type: Daily data | 2020-02-04 09:33:55.409 Historical data download ID 1 not found when removing ID from outstanding request set. | 2020-02-04 09:33:55.409 NQH20 [CV] Daily #16 | Reloading chart. | 2020-02-04 09:33:55.820 NQH20 [CV] Daily #16 | Limiting the number of years to download historical data for to 0 years for the continuous futures chart. Reason: Account level limitation. | 2020-02-04 09:33:55.820 NQH20 [CV] Daily #16 | Performing historical Daily data download for symbol NQH20 starting at last date in file. | 2020-02-04 09:33:55.821 Historical data service client indicated that downloads are not enabled. Symbol: NQH20. Data Type: Daily data | 2020-02-04 09:33:55.821 Historical data download ID 2 not found when removing ID from outstanding request set. | 2020-02-04 09:33:55.821 ZBH20 [CV] Daily #29 | Reloading chart. | 2020-02-04 09:33:56.162 ZBH20 [CV] Daily #29 | Limiting the number of years to download historical data for to 0 years for the continuous futures chart. Reason: Account level limitation. | 2020-02-04 09:33:56.162 ZBH20 [CV] Daily #29 | Performing historical Daily data download for symbol ZBH20 starting at last date in file. | 2020-02-04 09:33:56.163 Historical data service client indicated that downloads are not enabled. Symbol: ZBH20. Data Type: Daily data | 2020-02-04 09:33:56.163 Historical data download ID 3 not found when removing ID from outstanding request set. | 2020-02-04 09:33:56.163 CLZ19 [CBV] Daily #3 | Reloading chart. | 2020-02-04 09:33:56.569 CLZ19 [CBV] Daily #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2020-02-04 09:33:56.569 CLZ19 [CBV] Daily #3 | There are no continuous futures contract symbols. Loading data normally. | 2020-02-04 09:33:56.569 ZNH20 [CV] Daily #21 | Reloading chart. | 2020-02-04 09:33:56.595 ZNH20 [CV] Daily #21 | Limiting the number of years to download historical data for to 0 years for the continuous futures chart. Reason: Account level limitation. | 2020-02-04 09:33:56.595 ZNH20 [CV] Daily #21 | Performing historical Daily data download for symbol ZNH20 starting at last date in file. | 2020-02-04 09:33:56.597 Historical data service client indicated that downloads are not enabled. Symbol: ZNH20. Data Type: Daily data | 2020-02-04 09:33:56.597 Historical data download ID 4 not found when removing ID from outstanding request set. | 2020-02-04 09:33:56.597 ZTH20 [CV] Daily #31 | Reloading chart. | 2020-02-04 09:33:57.068 ZTH20 [CV] Daily #31 | Limiting the number of years to download historical data for to 0 years for the continuous futures chart. Reason: Account level limitation. | 2020-02-04 09:33:57.068 ZTH20 [CV] Daily #31 | Performing historical Daily data download for symbol ZTH20 starting at last date in file. | 2020-02-04 09:33:57.069 Historical data service client indicated that downloads are not enabled. Symbol: ZTH20. Data Type: Daily data | 2020-02-04 09:33:57.069 Historical data download ID 5 not found when removing ID from outstanding request set. | 2020-02-04 09:33:57.069 UBH20 [CV] Daily #32 | Reloading chart. | 2020-02-04 09:33:57.339 UBH20 [CV] Daily #32 | Limiting the number of years to download historical data for to 0 years for the continuous futures chart. Reason: Account level limitation. | 2020-02-04 09:33:57.339 UBH20 [CV] Daily #32 | Performing historical Daily data download for symbol UBH20 starting at last date in file. | 2020-02-04 09:33:57.340 Historical data service client indicated that downloads are not enabled. Symbol: UBH20. Data Type: Daily data | 2020-02-04 09:33:57.340 Historical data download ID 6 not found when removing ID from outstanding request set. | 2020-02-04 09:33:57.343 ZFH20 [CV] Daily #37 | Reloading chart. | 2020-02-04 09:33:57.429 ZFH20 [CV] Daily #37 | Limiting the number of years to download historical data for to 0 years for the continuous futures chart. Reason: Account level limitation. | 2020-02-04 09:33:57.429 ZFH20 [CV] Daily #37 | Performing historical Daily data download for symbol ZFH20 starting at last date in file. | 2020-02-04 09:33:57.430 Historical data service client indicated that downloads are not enabled. Symbol: ZFH20. Data Type: Daily data | 2020-02-04 09:33:57.430 Historical data download ID 7 not found when removing ID from outstanding request set. | 2020-02-04 09:33:57.430 ZCH20 [CV] Daily #41 | Reloading chart. | 2020-02-04 09:33:57.971 ZCH20 [CV] Daily #41 | Limiting the number of years to download historical data for to 0 years for the continuous futures chart. Reason: Account level limitation. | 2020-02-04 09:33:57.971 ZCH20 [CV] Daily #41 | Performing historical Daily data download for symbol ZCH20 starting at last date in file. | 2020-02-04 09:33:57.972 Historical data service client indicated that downloads are not enabled. Symbol: ZCH20. Data Type: Daily data | 2020-02-04 09:33:57.972 Historical data download ID 8 not found when removing ID from outstanding request set. | 2020-02-04 09:33:57.972 GCZ19 [CV] Daily #42 | Reloading chart. | 2020-02-04 09:33:58.701 GCZ19 [CV] Daily #42 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2020-02-04 09:33:58.701 GCZ19 [CV] Daily #42 | There are no continuous futures contract symbols. Loading data normally. | 2020-02-04 09:33:58.701 NGQ19 [CV] Daily #44 | Reloading chart. | 2020-02-04 09:33:58.802 NGQ19 [CV] Daily #44 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2020-02-04 09:33:58.802 NGQ19 [CV] Daily #44 | There are no continuous futures contract symbols. Loading data normally. | 2020-02-04 09:33:58.802 ZSH20 [CV] Daily #45 | Reloading chart. | 2020-02-04 09:33:58.832 ZSH20 [CV] Daily #45 | Limiting the number of years to download historical data for to 0 years for the continuous futures chart. Reason: Account level limitation. | 2020-02-04 09:33:58.832 ZSH20 [CV] Daily #45 | Performing historical Daily data download for symbol ZSH20 starting at last date in file. | 2020-02-04 09:33:58.833 Historical data service client indicated that downloads are not enabled. Symbol: ZSH20. Data Type: Daily data | 2020-02-04 09:33:58.833 Historical data download ID 9 not found when removing ID from outstanding request set. | 2020-02-04 09:33:58.833 ZWH20 [CV] Daily #48 | Reloading chart. | 2020-02-04 09:33:59.245 ZWH20 [CV] Daily #48 | Limiting the number of years to download historical data for to 0 years for the continuous futures chart. Reason: Account level limitation. | 2020-02-04 09:33:59.245 ZWH20 [CV] Daily #48 | Performing historical Daily data download for symbol ZWH20 starting at last date in file. | 2020-02-04 09:33:59.246 Historical data service client indicated that downloads are not enabled. Symbol: ZWH20. Data Type: Daily data | 2020-02-04 09:33:59.246 Historical data download ID 10 not found when removing ID from outstanding request set. | 2020-02-04 09:33:59.246 FGBLH20 [CV] Daily #49 | Reloading chart. | 2020-02-04 09:33:59.654 FGBLH20 [CV] Daily #49 | Limiting the number of years to download historical data for to 0 years for the continuous futures chart. Reason: Account level limitation. | 2020-02-04 09:33:59.654 FGBLH20 [CV] Daily #49 | Performing historical Daily data download for symbol FGBLH20 starting at last date in file. | 2020-02-04 09:33:59.655 Historical data service client indicated that downloads are not enabled. Symbol: FGBLH20. Data Type: Daily data | 2020-02-04 09:33:59.655 Historical data download ID 11 not found when removing ID from outstanding request set. | 2020-02-04 09:33:59.655 FESXH20 [CV] Daily #50 | Reloading chart. | 2020-02-04 09:33:59.726 FESXH20 [CV] Daily #50 | Limiting the number of years to download historical data for to 0 years for the continuous futures chart. Reason: Account level limitation. | 2020-02-04 09:33:59.726 FESXH20 [CV] Daily #50 | Performing historical Daily data download for symbol FESXH20 starting at last date in file. | 2020-02-04 09:33:59.727 Historical data service client indicated that downloads are not enabled. Symbol: FESXH20. Data Type: Daily data | 2020-02-04 09:33:59.727 Historical data download ID 12 not found when removing ID from outstanding request set. | 2020-02-04 09:33:59.727 NKDH20 [CV] Daily #51 | Reloading chart. | 2020-02-04 09:33:59.802 NKDH20 [CV] Daily #51 | Limiting the number of years to download historical data for to 0 years for the continuous futures chart. Reason: Account level limitation. | 2020-02-04 09:33:59.802 NKDH20 [CV] Daily #51 | Performing historical Daily data download for symbol NKDH20 starting at last date in file. | 2020-02-04 09:33:59.803 Historical data service client indicated that downloads are not enabled. Symbol: NKDH20. Data Type: Daily data | 2020-02-04 09:33:59.803 Historical data download ID 13 not found when removing ID from outstanding request set. | 2020-02-04 09:33:59.803 EUSTX50 Daily #52 | Reloading chart. | 2020-02-04 09:33:59.881 Bund Daily #53 | Reloading chart. | 2020-02-04 09:33:59.921 US2000 Daily #57 | Reloading chart. | 2020-02-04 09:33:59.950 UKOil Daily #58 | Reloading chart. | 2020-02-04 09:33:59.981 ES02142019 3 Min #59 | Reloading chart. | 2020-02-04 09:34:00.024 Using SC exchange feed2. Symbol: GNG?## | 2020-02-04 09:34:00.060 GNGH20 3 Min #62 | Reloading chart. | 2020-02-04 09:34:00.060 GNGH20 [CV] Daily #63 | Reloading chart. | 2020-02-04 09:34:00.182 GNGH20 [CV] Daily #63 | Limiting the number of years to download historical data for to 0 years for the continuous futures chart. Reason: Account level limitation. | 2020-02-04 09:34:00.182 GNGH20 [CV] Daily #63 | Performing historical Daily data download for symbol GNGH20 starting at last date in file. | 2020-02-04 09:34:00.184 Historical data service client indicated that downloads are not enabled. Symbol: GNGH20. Data Type: Daily data | 2020-02-04 09:34:00.184 Historical data download ID 14 not found when removing ID from outstanding request set. | 2020-02-04 09:34:00.184 Using SC exchange feed2. Symbol: ZN?## | 2020-02-04 09:34:00.491 ZNZ19 3 Min #65 | Reloading chart. | 2020-02-04 09:34:00.491 Using SC exchange feed2. Symbol: ES?## | 2020-02-04 09:34:00.533 ESZ19 3 Min #68 | Reloading chart. | 2020-02-04 09:34:00.534 ZN02142019 3 Min #69 | Reloading chart. | 2020-02-04 09:34:00.923 Using SC exchange feed2. Symbol: ZB?## | 2020-02-04 09:34:01.051 ZBZ16 3 Min #72 | Reloading chart. | 2020-02-04 09:34:01.052 SP500-I Daily #19 | Reloading chart. | 2020-02-04 09:34:01.169 TPO Profile Chart | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-02-04 09:34:01.324 * TPO Profile Chart | To restore the chart, remove this study. | 2020-02-04 09:34:01.324 * GGCJ20 3 Min #47 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Program Files (x86)\SierraChart\Data\GGCJ20.scid | 2020-02-04 09:34:01.328 TFM11 3 Min #88 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Program Files (x86)\SierraChart\Data\TFM11.scid | 2020-02-04 09:34:01.429 TPO Profile Chart | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-02-04 09:34:01.898 * TPO Profile Chart | To restore the chart, remove this study. | 2020-02-04 09:34:01.898 * TPO Profile Chart | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-02-04 09:34:01.913 * TPO Profile Chart | To restore the chart, remove this study. | 2020-02-04 09:34:01.913 * TPO Profile Chart | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-02-04 09:34:01.940 * TPO Profile Chart | To restore the chart, remove this study. | 2020-02-04 09:34:01.940 * TPO Profile Chart | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-02-04 09:34:01.947 * TPO Profile Chart | To restore the chart, remove this study. | 2020-02-04 09:34:01.947 * TPO Profile Chart | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-02-04 09:34:02.013 * TPO Profile Chart | To restore the chart, remove this study. | 2020-02-04 09:34:02.013 * TPO Profile Chart | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-02-04 09:34:02.272 * TPO Profile Chart | To restore the chart, remove this study. | 2020-02-04 09:34:02.272 * TPO Profile Chart | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-02-04 09:34:02.281 * TPO Profile Chart | To restore the chart, remove this study. | 2020-02-04 09:34:02.281 * Using SC exchange feed2. Symbol: ZC?## | 2020-02-04 09:34:03.384 Using SC exchange feed2. Symbol: ZC?## | 2020-02-04 09:34:03.384 Starting DelayedDownloadMonitoringTimer | 2020-02-04 09:34:03.384 Starting HDTimeoutTimer | 2020-02-04 09:34:03.384 Historical data service client indicated that downloads are not enabled. Symbol: ZCH20. Data Type: Intraday data | 2020-02-04 09:34:03.384 Historical data download ID 15 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.384 Historical data service client indicated that downloads are not enabled. Symbol: VXH16. Data Type: Intraday data | 2020-02-04 09:34:03.396 Historical data download ID 16 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.397 Historical data service client indicated that downloads are not enabled. Symbol: FESXH20. Data Type: Intraday data | 2020-02-04 09:34:03.402 Historical data download ID 17 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.403 TPO Profile Chart | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-02-04 09:34:03.403 * TPO Profile Chart | To restore the chart, remove this study. | 2020-02-04 09:34:03.403 * Historical data service client indicated that downloads are not enabled. Symbol: EURUSD. Data Type: Daily data | 2020-02-04 09:34:03.414 Historical data download ID 18 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.414 Using Bid/Ask average for last trade price for EURUSD | 2020-02-04 09:34:03.414 Historical data service client indicated that downloads are not enabled. Symbol: FESXH18. Data Type: Intraday data | 2020-02-04 09:34:03.435 Historical data download ID 19 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.435 Historical data service client indicated that downloads are not enabled. Symbol: FESXM12. Data Type: Intraday data | 2020-02-04 09:34:03.447 Historical data download ID 20 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.447 Historical data service client indicated that downloads are not enabled. Symbol: FGBLH20. Data Type: Intraday data | 2020-02-04 09:34:03.892 Historical data download ID 21 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.892 Using SC exchange feed2. Symbol: GCL?## | 2020-02-04 09:34:03.897 Using SC exchange feed2. Symbol: GCL?## | 2020-02-04 09:34:03.898 Historical data service client indicated that downloads are not enabled. Symbol: GCLZ20. Data Type: Intraday data | 2020-02-04 09:34:03.898 Historical data download ID 22 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.898 Using SC exchange feed2. Symbol: ES?## | 2020-02-04 09:34:03.904 Using SC exchange feed2. Symbol: ES?## | 2020-02-04 09:34:03.904 Historical data service client indicated that downloads are not enabled. Symbol: ESH20. Data Type: Intraday data | 2020-02-04 09:34:03.904 Historical data download ID 23 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.904 TPO Profile Chart | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-02-04 09:34:03.904 * TPO Profile Chart | To restore the chart, remove this study. | 2020-02-04 09:34:03.904 * Connect to Data Feed | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-02-04 09:34:03.904 * Using SC exchange feed2. Symbol: GGC?## | 2020-02-04 09:34:03.904 Using SC exchange feed2. Symbol: GGC?## | 2020-02-04 09:34:03.904 Historical data service client indicated that downloads are not enabled. Symbol: GGCJ20. Data Type: Intraday data | 2020-02-04 09:34:03.904 Historical data download ID 24 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.905 Historical data service client indicated that downloads are not enabled. Symbol: USDJPY. Data Type: Daily data | 2020-02-04 09:34:03.905 Historical data download ID 25 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.905 Using Bid/Ask average for last trade price for USDJPY | 2020-02-04 09:34:03.905 Historical data service client indicated that downloads are not enabled. Symbol: $VIX. Data Type: Daily data | 2020-02-04 09:34:03.919 Historical data download ID 26 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.919 Historical data service client indicated that downloads are not enabled. Symbol: $TYX. Data Type: Daily data | 2020-02-04 09:34:03.925 Historical data download ID 27 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.925 Using SC exchange feed2. Symbol: NKD?## | 2020-02-04 09:34:03.933 Using SC exchange feed2. Symbol: NKD?## | 2020-02-04 09:34:03.933 Historical data service client indicated that downloads are not enabled. Symbol: NKDH20. Data Type: Intraday data | 2020-02-04 09:34:03.933 Historical data download ID 28 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.933 Historical data service client indicated that downloads are not enabled. Symbol: CT-MH20. Data Type: Intraday data | 2020-02-04 09:34:03.939 Historical data download ID 29 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.939 Historical data service client indicated that downloads are not enabled. Symbol: KCN11. Data Type: Daily data | 2020-02-04 09:34:03.943 Historical data download ID 30 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.943 Historical data service client indicated that downloads are not enabled. Symbol: KC-MH20. Data Type: Intraday data | 2020-02-04 09:34:03.949 Historical data download ID 31 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.949 Historical data service client indicated that downloads are not enabled. Symbol: CCN11. Data Type: Daily data | 2020-02-04 09:34:03.955 Historical data download ID 32 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.955 Historical data service client indicated that downloads are not enabled. Symbol: FGBLZ16. Data Type: Intraday data | 2020-02-04 09:34:03.963 Historical data download ID 33 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.963 Historical data service client indicated that downloads are not enabled. Symbol: VXG20. Data Type: Intraday data | 2020-02-04 09:34:03.970 Historical data download ID 34 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.970 Connect to Data Feed | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-02-04 09:34:03.974 * Historical data service client indicated that downloads are not enabled. Symbol: $FVX. Data Type: Daily data | 2020-02-04 09:34:03.975 Historical data download ID 35 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.975 Using SC exchange feed2. Symbol: ZB?## | 2020-02-04 09:34:03.982 Using SC exchange feed2. Symbol: ZB?## | 2020-02-04 09:34:03.982 Historical data service client indicated that downloads are not enabled. Symbol: ZBH20. Data Type: Intraday data | 2020-02-04 09:34:03.982 Historical data download ID 36 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.982 TPO Profile Chart | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-02-04 09:34:03.982 * TPO Profile Chart | To restore the chart, remove this study. | 2020-02-04 09:34:03.982 * Using SC exchange feed2. Symbol: GCL?## | 2020-02-04 09:34:03.984 Using SC exchange feed2. Symbol: GCL?## | 2020-02-04 09:34:03.984 Historical data service client indicated that downloads are not enabled. Symbol: GCLH20. Data Type: Intraday data | 2020-02-04 09:34:03.984 Historical data download ID 37 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.984 Historical data service client indicated that downloads are not enabled. Symbol: FGBLU18. Data Type: Intraday data | 2020-02-04 09:34:03.992 Historical data download ID 38 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.992 Historical data service client indicated that downloads are not enabled. Symbol: FGBLU15. Data Type: Intraday data | 2020-02-04 09:34:03.999 Historical data download ID 39 not found when removing ID from outstanding request set. | 2020-02-04 09:34:03.999 TPO Profile Chart | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-02-04 09:34:03.999 * TPO Profile Chart | To restore the chart, remove this study. | 2020-02-04 09:34:03.999 * Using SC exchange feed2. Symbol: GSI?## | 2020-02-04 09:34:04.001 Using SC exchange feed2. Symbol: GSI?## | 2020-02-04 09:34:04.001 Historical data service client indicated that downloads are not enabled. Symbol: GSIH20. Data Type: Intraday data | 2020-02-04 09:34:04.001 Historical data download ID 40 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.001 Using SC exchange feed2. Symbol: ZC?## | 2020-02-04 09:34:04.007 Using SC exchange feed2. Symbol: ZC?## | 2020-02-04 09:34:04.008 Historical data service client indicated that downloads are not enabled. Symbol: ZCZ15. Data Type: Intraday data | 2020-02-04 09:34:04.008 Historical data download ID 41 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.008 Using SC exchange feed2. Symbol: ES?## | 2020-02-04 09:34:04.012 Using SC exchange feed2. Symbol: ES?## | 2020-02-04 09:34:04.012 Historical data service client indicated that downloads are not enabled. Symbol: ESZ18. Data Type: Intraday data | 2020-02-04 09:34:04.012 Historical data download ID 42 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.012 Historical data service client indicated that downloads are not enabled. Symbol: NGN13. Data Type: Daily data | 2020-02-04 09:34:04.019 Historical data download ID 43 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.019 TPO Profile Chart | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-02-04 09:34:04.025 * TPO Profile Chart | To restore the chart, remove this study. | 2020-02-04 09:34:04.025 * Using SC exchange feed2. Symbol: GCL?## | 2020-02-04 09:34:04.026 Using SC exchange feed2. Symbol: GCL?## | 2020-02-04 09:34:04.026 Historical data service client indicated that downloads are not enabled. Symbol: GCLZ18. Data Type: Intraday data | 2020-02-04 09:34:04.026 Historical data download ID 44 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.026 Using SC exchange feed2. Symbol: GNG?## | 2020-02-04 09:34:04.032 Using SC exchange feed2. Symbol: GNG?## | 2020-02-04 09:34:04.032 Historical data service client indicated that downloads are not enabled. Symbol: GNGX18. Data Type: Intraday data | 2020-02-04 09:34:04.032 Historical data download ID 45 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.032 TPO Profile Chart | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-02-04 09:34:04.033 * TPO Profile Chart | To restore the chart, remove this study. | 2020-02-04 09:34:04.033 * Using SC exchange feed2. Symbol: ZS?## | 2020-02-04 09:34:04.034 Using SC exchange feed2. Symbol: ZS?## | 2020-02-04 09:34:04.034 Historical data service client indicated that downloads are not enabled. Symbol: ZSH20. Data Type: Intraday data | 2020-02-04 09:34:04.034 Historical data download ID 46 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.034 Using SC exchange feed2. Symbol: ZN?## | 2020-02-04 09:34:04.039 Using SC exchange feed2. Symbol: ZN?## | 2020-02-04 09:34:04.040 Historical data service client indicated that downloads are not enabled. Symbol: ZNH20. Data Type: Intraday data | 2020-02-04 09:34:04.040 Historical data download ID 47 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.040 TPO Profile Chart | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-02-04 09:34:04.040 * TPO Profile Chart | To restore the chart, remove this study. | 2020-02-04 09:34:04.040 * Using SC exchange feed2. Symbol: GGC?## | 2020-02-04 09:34:04.042 Using SC exchange feed2. Symbol: GGC?## | 2020-02-04 09:34:04.042 Historical data service client indicated that downloads are not enabled. Symbol: GGCQ18. Data Type: Intraday data | 2020-02-04 09:34:04.042 Historical data download ID 48 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.042 TPO Profile Chart | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-02-04 09:34:04.042 * TPO Profile Chart | To restore the chart, remove this study. | 2020-02-04 09:34:04.042 * Using SC exchange feed2. Symbol: NKD?## | 2020-02-04 09:34:04.043 Using SC exchange feed2. Symbol: NKD?## | 2020-02-04 09:34:04.043 Historical data service client indicated that downloads are not enabled. Symbol: NKDZ15. Data Type: Intraday data | 2020-02-04 09:34:04.043 Historical data download ID 49 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.043 Using SC exchange feed2. Symbol: ES?## | 2020-02-04 09:34:04.055 Using SC exchange feed2. Symbol: ES?## | 2020-02-04 09:34:04.055 Historical data service client indicated that downloads are not enabled. Symbol: ESM19. Data Type: Intraday data | 2020-02-04 09:34:04.055 Historical data download ID 50 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.055 Using SC exchange feed2. Symbol: ES?## | 2020-02-04 09:34:04.059 Using SC exchange feed2. Symbol: ES?## | 2020-02-04 09:34:04.059 Historical data service client indicated that downloads are not enabled. Symbol: ESU19. Data Type: Intraday data | 2020-02-04 09:34:04.060 Historical data download ID 51 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.060 Historical data service client indicated that downloads are not enabled. Symbol: $SPX. Data Type: Daily data | 2020-02-04 09:34:04.069 Historical data download ID 52 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.069 Using SC exchange feed2. Symbol: ZN?## | 2020-02-04 09:34:04.083 Using SC exchange feed2. Symbol: ZN?## | 2020-02-04 09:34:04.084 Historical data service client indicated that downloads are not enabled. Symbol: ZNU19. Data Type: Intraday data | 2020-02-04 09:34:04.084 Historical data download ID 53 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.084 Using SC exchange feed2. Symbol: ZB?## | 2020-02-04 09:34:04.090 Using SC exchange feed2. Symbol: ZB?## | 2020-02-04 09:34:04.090 Historical data service client indicated that downloads are not enabled. Symbol: ZBU18. Data Type: Intraday data | 2020-02-04 09:34:04.090 Historical data download ID 54 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.090 Historical data service client indicated that downloads are not enabled. Symbol: $TNX. Data Type: Daily data | 2020-02-04 09:34:04.095 Historical data download ID 55 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.095 Using SC exchange feed2. Symbol: ZB?## | 2020-02-04 09:34:04.103 Using SC exchange feed2. Symbol: ZB?## | 2020-02-04 09:34:04.103 Historical data service client indicated that downloads are not enabled. Symbol: ZBM18. Data Type: Intraday data | 2020-02-04 09:34:04.103 Historical data download ID 56 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.103 Using SC exchange feed2. Symbol: ZN?## | 2020-02-04 09:34:04.118 Using SC exchange feed2. Symbol: ZN?## | 2020-02-04 09:34:04.118 Historical data service client indicated that downloads are not enabled. Symbol: ZNM19. Data Type: Intraday data | 2020-02-04 09:34:04.118 Historical data download ID 57 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.118 Using SC exchange feed2. Symbol: NQ?## | 2020-02-04 09:34:04.139 Historical data service client indicated that downloads are not enabled. Symbol: CLZ19. Data Type: Daily data | 2020-02-04 09:34:04.148 Historical data download ID 58 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.149 Using SC exchange feed2. Symbol: ZT?## | 2020-02-04 09:34:04.160 Using SC exchange feed2. Symbol: UB?## | 2020-02-04 09:34:04.166 Using SC exchange feed2. Symbol: ZF?## | 2020-02-04 09:34:04.170 Historical data service client indicated that downloads are not enabled. Symbol: GCZ19. Data Type: Daily data | 2020-02-04 09:34:04.182 Historical data download ID 59 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.182 Historical data service client indicated that downloads are not enabled. Symbol: NGQ19. Data Type: Daily data | 2020-02-04 09:34:04.188 Historical data download ID 60 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.188 Using SC exchange feed2. Symbol: ZW?## | 2020-02-04 09:34:04.199 Historical data service client indicated that downloads are not enabled. Symbol: EUSTX50. Data Type: Daily data | 2020-02-04 09:34:04.216 Historical data download ID 61 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.216 Using Bid/Ask average for last trade price for EUSTX50 | 2020-02-04 09:34:04.216 Historical data service client indicated that downloads are not enabled. Symbol: Bund. Data Type: Daily data | 2020-02-04 09:34:04.222 Historical data download ID 62 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.222 Using Bid/Ask average for last trade price for Bund | 2020-02-04 09:34:04.222 Historical data service client indicated that downloads are not enabled. Symbol: US2000. Data Type: Daily data | 2020-02-04 09:34:04.271 Historical data download ID 63 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.271 Using Bid/Ask average for last trade price for US2000 | 2020-02-04 09:34:04.271 Historical data service client indicated that downloads are not enabled. Symbol: UKOil. Data Type: Daily data | 2020-02-04 09:34:04.277 Historical data download ID 64 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.277 Using Bid/Ask average for last trade price for UKOil | 2020-02-04 09:34:04.277 Using SC exchange feed2. Symbol: GNG?## | 2020-02-04 09:34:04.286 Using SC exchange feed2. Symbol: GNG?## | 2020-02-04 09:34:04.286 Historical data service client indicated that downloads are not enabled. Symbol: GNGH20. Data Type: Intraday data | 2020-02-04 09:34:04.286 Historical data download ID 65 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.286 Using SC exchange feed2. Symbol: ZN?## | 2020-02-04 09:34:04.296 Using SC exchange feed2. Symbol: ZN?## | 2020-02-04 09:34:04.296 Historical data service client indicated that downloads are not enabled. Symbol: ZNZ19. Data Type: Intraday data | 2020-02-04 09:34:04.296 Historical data download ID 66 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.296 Using SC exchange feed2. Symbol: ES?## | 2020-02-04 09:34:04.302 Using SC exchange feed2. Symbol: ES?## | 2020-02-04 09:34:04.302 Historical data service client indicated that downloads are not enabled. Symbol: ESZ19. Data Type: Intraday data | 2020-02-04 09:34:04.302 Historical data download ID 67 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.302 Using SC exchange feed2. Symbol: ZB?## | 2020-02-04 09:34:04.322 Using SC exchange feed2. Symbol: ZB?## | 2020-02-04 09:34:04.323 Historical data service client indicated that downloads are not enabled. Symbol: ZBZ16. Data Type: Intraday data | 2020-02-04 09:34:04.323 Historical data download ID 68 not found when removing ID from outstanding request set. | 2020-02-04 09:34:04.323 Historical data service client indicated that downloads are not enabled. Symbol: $TYX. Data Type: Daily data | 2020-02-04 09:34:24.512 Historical data download ID 69 not found when removing ID from outstanding request set. | 2020-02-04 09:34:24.512 Starting downloads for all open Historical Daily data charts. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: EURUSD. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 70 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: USDJPY. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 71 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: $VIX. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 72 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: $TYX. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 73 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: KCN11. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 74 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: CCN11. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 75 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: $FVX. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 76 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: NGN13. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 77 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 No historical data client is currently set to download historical Daily data for $KSIC. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: $SPX. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 78 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 No historical data client is currently set to download historical Daily data for SP500-I. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: $TNX. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 79 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: $TNX. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 80 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: $SPX. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 81 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: ESH20. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 82 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: NQH20. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 83 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: ZBH20. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 84 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: CLZ19. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 85 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: ZNH20. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 86 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: ZTH20. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 87 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: UBH20. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 88 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: ZFH20. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 89 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: ZCH20. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 90 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: GCZ19. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 91 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: NGQ19. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 92 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: ZSH20. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 93 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: ZWH20. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 94 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: FGBLH20. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 95 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: FESXH20. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 96 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: NKDH20. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 97 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: EUSTX50. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 98 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: Bund. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 99 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: US2000. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 100 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: UKOil. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 101 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 Historical data service client indicated that downloads are not enabled. Symbol: GNGH20. Data Type: Daily data | 2020-02-04 13:46:17.703 Historical data download ID 102 not found when removing ID from outstanding request set. | 2020-02-04 13:46:17.703 No historical data client is currently set to download historical Daily data for SP500-I. | 2020-02-04 13:46:17.703 Connect to Data Feed | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-02-04 13:53:38.654 * |
[2020-02-04 21:10:04] |
You need to update Sierra Chart to the latest prerelease. Follow the instructions here: Software Download: Fast Update Make sure you select Help >> Download Prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
