Date/Time: Sat, 27 Apr 2024 08:42:09 +0000
Spreadsheet Closed Daily Profit/Loss (read only) cell j45
View Count: 898
[2020-02-03 22:00:50] |
joer - Posts: 41 |
While running an Autotrade System Replay Backtest, this field, j45, does not reset to zero when a new day is started. I'm running release 2040. Never had this problem before, just installed 2040 today. I ran a backtest for 30 days and some days it resets to zero and other days it does not. I'm using your data feed for this testing, symbol clh20 5 min chart. For example, I paused the test in the middle of a day that had no trades and the Closed Daily Profit/Loss cell shows 420. |
[2020-02-03 22:13:05] |
This will be resolved in the next release.
[2020-05-23 15:51:10] |
User476002 - Posts: 28 |
I still have this issue, I'm using the current version
[2020-05-25 13:16:44] |
Describe the exact problem you are having. Also refer to: Trade Activity Log: Understanding Daily Trade Statistics Reset Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-25 13:51:47] |
when I run a backtest J45 is a day behind. Also the daily win loss stats are a day behind. So the same as the original post, when I pause and look at the spreadsheet on a day with no trades it still has the daily stats from the day before. I've tried adjusting the session times and no improvement. thanks
[2020-05-25 19:33:46] |
And what are the Session Times in the Chart Settings set to? Did you read this section?: Trade Activity Log: Understanding Daily Trade Statistics Reset Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-26 01:16:53
