Date/Time: Mon, 29 Apr 2024 04:35:13 +0000
Re:New Sierra charts real time/historical chart data feed
View Count: 1153
[2014-01-05 14:25:57] |
User41512 - Posts: 58 |
hi, I wanted to confirm a few details of the new offering from SC. (I presently use an external data feed from IQ Feed): a/ you have a number of exchanges available specifically the EUREX & CME ? b/ The feed can be used for both SC intraday and historical charts. c/ The Data-feed is available on a tic by tic basis. d/ all volume related studies, numbers bars, TPO details etc would still be available when using this alternative feed. e/ Would there be any chart types/studies which would not be available when using this new feed, which i can currently use/receive when using IQ feed. f/ Is the cost of $35 payable on a month by month basis, or do you need to commit to a longer term agreement. g/ for each additional exchange required the additional cost is $20? If you need to run sierra charts (with the new data-feed)on a different machine for what ever reason, i assume as long as only 1 copy of SC is open at a time,there would be no additional costs for doing that. h/ you do not have to integrate the data feed with the trading service providers you have listed. ie i can continue to use a separate third party broker, whilst using my sierra charts (with the new data-feed) on a standalone basis. Thanks |
[2014-01-06 02:54:57] |
The answer is Yes to all of your questions with the following notes: You can use all of the Sierra Chart studies with this data feed. The 20 USD per month fee you refer to has to do with additional simultaneous connections. It is not related to exchanges. h/ you do not have to integrate the data feed with the trading service providers you have listed. ie i can continue to use a separate third party broker, whilst using my sierra charts (with the new data-feed) on a standalone basis.
For CME data, you do have to use one of the Sierra Chart supported trading services.Also, this page here also answers your questions: http://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
