Date/Time: Tue, 30 Apr 2024 08:07:08 +0000
soybean prices
View Count: 1309
[2014-01-05 14:14:50] |
User57072 - Posts: 49 |
how is the soybean prices configured?
[2014-01-05 19:17:57] |
We do not understand this question.
[2014-01-06 14:20:08] |
How is the price scale for soybeans configured to show cents/lb ?
[2014-01-06 19:13:52] |
Could you please provide us an image of the chart so we can see what symbol you are using and we will make sure that the settings are proper for that symbol. Here are the instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-06 23:17:00] |
Here is the image showing the Soybean price scale. http://www.sierrachart.com/image.php?l=138904989280.png |
[2014-01-07 01:12:18] |
We have corrected the Symbol Settings. "Update" the symbol settings as explained here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
