Date/Time: Sun, 05 May 2024 19:40:54 +0000
worksheet study, use variable attached stops
View Count: 1000
[2014-01-05 11:50:26] |
pkhst958 - Posts: 53 |
Hi, I use the worksheet study for automated trading. I use attached stops. I would like to change the amount of the attached stop depending on the conditions at the entry. How can I do that? |
[2014-01-08 01:43:25] |
This is supported with the Spreadsheet System for Trading study and you need to use the following Spreadsheet Inputs: http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#AttachedOrderTargetOffset J80 and J81 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
