Date/Time: Sun, 05 May 2024 17:25:20 +0000
[User Discussion] - Data Compression and Folder Size
View Count: 531
[2020-02-01 22:20:28] |
User750920 - Posts: 274 |
Every week I copy the entire Sierra Folder to a backup drive "just in case". Today (Saturday Feb 1) I accidentally deleted the Sierra Folder in the C: drive (while cleaning up the drive). Fortunately I had copied it into the other drive and simply copied it back to the C: drive. After I started Sierra again it prompted me to download the current version. I did no issues. After I loaded all my chartbooks I notice the File Folder size size on disk (save to disk) is no longer compressed. Prior to this the File Folder size was 74+GB and the File Folder size on disk (saved to disk) was around 30+ GB. Now they are about the same. Anything I can do to fix this or is up to the Sierra program to eventually compress this Folder again. Thank you for the help. Date Time Of Last Edit: 2020-02-01 22:25:44
[2020-02-05 19:16:14] |
Wanted to Bump this - Thanks.
