Date/Time: Mon, 06 May 2024 13:21:54 +0000
[Programming Help] - How to add comment in alert pane
View Count: 823
[2020-01-31 14:36:37] |
Tariq - Posts: 16 |
Some times the code gets too convoluted to read what I was intending to do. so I would like to add comment in the alert pane either above or below the code. Is it possible?
alert pane.PNG / V - Attached On 2020-01-31 14:32:14 UTC - Size: 10.12 KB - 250 views |
[2020-01-31 22:08:05] |
Sierra_Chart Engineering - Posts: 14244 |
No, that is not possible and you should switch to ACSIL for more complex formulas.
[2020-01-31 23:29:53] |
Sawtooth - Posts: 3993 |
Alert syntax will ignore line feeds, so you can organize formulas, like this: =OR( AND(ID7.SG3[0] > ID7.SG3[-1],ID7.SG3[-1] <= ID7.SG3[-2]), AND(ID7.SG3[0] < ID7.SG3[-1],ID7.SG3[-1] >= ID7.SG3[-2])) |
