Date/Time: Wed, 08 May 2024 21:21:55 +0000
current ensign software user
View Count: 1985
[2014-01-05 04:07:57] |
User68820 - Posts: 1 |
Hi, My name is Scott, my broker is amp. I received an email from them about SC and decided to look over the software. My question is simple, I have a custom indicator I use/designed in Ensign. It is the spread between 2 weighted moving averages shown as a histogram that changes colors if it is rising or falling. The screenshot attached shows 4 different spreads shown either as a line or histogram. is it possible to create this using SC?
Date Time Of Last Edit: 2014-01-05 04:17:25
sample.jpg / V - Attached On 2014-01-05 04:16:35 UTC - Size: 311.68 KB - 482 views Attachment Deleted. |
[2014-01-05 04:39:02] |
Yes. This is very possible and easy to do in Sierra Chart. There is no custom programming needed.
