Date/Time: Sun, 05 May 2024 06:38:28 +0000
Loading new symbol via Quoteboard, and adjusting the right scale level
View Count: 611
[2020-01-31 12:18:04] |
User164231 - Posts: 278 |
Hi, I have a quote board filled with symbols which I linked to a chart. When I tried to click on any symbol to load the chart the candles are always compressed into a horizontal line and I have to spend a lot of time to adjust to the right level. I have to repeat the process over and over again every time I click on a new symbol. There should be an automatic way to expand the candles right? Date Time Of Last Edit: 2020-01-31 12:28:20
we'ge'neUntitled.jpg / V - Attached On 2020-01-31 12:17:26 UTC - Size: 107.62 KB - 233 views |
[2020-01-31 22:09:35] |
Make sure the chart scale is set to Automatic. Refer to the following: Chart Scale and Scale Adjusting: Automatic (Scale Range) Also refer to the following for how to Reset the scales: Chart Scale and Scale Adjusting: Resetting the Scale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-31 22:09:49
[2020-02-01 14:17:57] |
Thanks I have followed your instructions but it didn't work, there is a bug there. The only work around is to enable the chart trade mode so that I could use the 'autoscale the dom' function to expand the candles to almost the right size and adjust a little from there. Surely there is a better way out. |
Attachment Deleted. |
