Date/Time: Mon, 29 Apr 2024 16:21:21 +0000
VerticalTimeLine Study - Bug
View Count: 903
[2020-01-31 10:38:28] |
User722856 - Posts: 78 |
Dear Sierra, I think I found a BUG in the “VerticalTimeLine” Study (SierraChartStudies_64.scsf_VerticalTimeLine). The BUG occurs when using this Study in combination with the “Time Price Opportunity (TPO) Profile Charts” Study. Even though the Time-Lines are set in the Studies, there are not being displayed, this occurs every time I open the Chartbook. After I open the chartbook I need manually go to study settings and click Apply, after that the timelines are getting displayed. Please help. Best regards BUG after opening the Chartbook - no timelines: http://www.sierrachart.com/image.php?Image=1580467043649.png Time-Lines after clicking apply in the studies: http://www.sierrachart.com/image.php?Image=1580466895261.png Date Time Of Last Edit: 2020-01-31 10:39:00
[2020-01-31 11:16:33] |
Refer to: Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-31 11:19:10] |
Thank you, didn't know.
