Date/Time: Sun, 05 May 2024 17:48:08 +0000
Toolbar, DOM, and Tabs button Freeze
View Count: 1420
[2020-02-07 19:02:32] |
We think we know what the problem is related to and we will put out a new release later today.
[2020-02-07 19:54:17] |
We are putting out a new release in about 20 minutes. The issue was on the Sierra Chart side all along. What was happening was there was a condition where the Pointer input capture was not being released from the tab controls.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-07 19:54:34
[2020-02-07 19:58:46] |
Trader&Hunter - Posts: 129 |
ok, sounds good.
[2020-02-07 21:07:50] |
We have released version 2047 which you can update to now.
[2020-02-07 21:14:44] |
So does this fix my original problem or the problem after 2046 pre release?
[2020-02-07 21:39:31] |
It fixes the original problem in its entirety.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-07 21:39:49
