Date/Time: Thu, 02 May 2024 11:25:55 +0000
keep specific drawings from being drawn on other charts
View Count: 603
[2020-01-30 09:27:21] |
User735389 - Posts: 188 |
with the "copy drawings from other charts" feature on, is there a way to still have specific drawings to not show on other charts?
[2020-01-30 18:21:13] |
Sierra_Chart Engineering - Posts: 14173 |
No, this is not supported.
[2020-01-31 11:09:13] |
AddAsUserDrawing doesn't copy to other charts correct? Do you guys plan on changing that behavior? Please confirm, because i think i can get my desired behavior using this function.
[2020-02-01 08:32:58] |
We will see about adding a flag variable to support copying ACSIL user drawn drawings to other charts.
[2020-02-01 10:19:31] |
User658985 - Posts: 30 |
thanks! to confirm, i actually need the opposite feature; a flag to stop a drawing from copying to other charts. I ended up doing a hack that would hide the User Drawing made by me, then replace it with an ASCIL user drawing (which would only show on the chart it was created for). To modify the drawing, i have a toggle between the original drawing and acsil drawing. I need to keep the original drawing so it still saves in the chartbook. |
[2020-02-01 10:29:25] |
Actually, one feature that would help ALOT is a hidden string property for chart drawings, that saves into the chartbook. that way i can create addition properties for a drawing by serializing a string. it'll add a whole new dimension in terms of flexibility. right now i do this with the normal text property with special chars, but its limiting without really cluttering the chart.
[2020-02-05 18:34:16] |
Both in ACSIL and through the Chart Drawing shortcut menu you will be able to control whether a drawing is copied to another chart or not. This will be out in the next release.
[2020-02-06 00:57:03] |
perfect, thnx!
