Date/Time: Mon, 06 May 2024 06:20:35 +0000
LMAX Digital
View Count: 1001
[2020-01-29 23:18:23] |
BeardPower - Posts: 51 |
Hello, Is there a special connection needed for LMAX Digital (https://www.lmaxdigital.com/), or is there some activation needed? Thank you! |
[2020-01-30 06:38:01] |
Not sure about this. Sierra Chart does already list various crypto currencies from LMAX. So those can be traded at this time.
[2020-01-30 11:35:16] |
Yes, that's correct, but LMAX Digital is the institutional cryptocurrency exchange from the LMAX Exchange Group. LMAX Digital responded, that Sierra Charts has not yet integrated LMAX Digital and that I should reach out to you guys for that matter. The APIs are the same so I assume it would just need an additional LMAX setting like the one for New Zealand? https://www.lmaxdigital.com/documents/LMAX-Digital-Connectivity-Overview.pdf It would be great if you could look into that. |
[2020-01-30 18:30:15] |
Sierra_Chart Engineering - Posts: 14239 |
We will contact LMAX about this.
[2020-02-07 15:00:17] |
Is there any update on this?
[2020-02-08 04:44:41] |
They say it is an institutional exchange. They wanted to know about who was interested in it and that is not a question we can answer.
