Date/Time: Fri, 03 May 2024 03:50:08 +0000
DTS Config Saved Location
View Count: 1446
[2020-01-29 22:37:35] |
User94606 - Posts: 327 |
Can you tell where this configuration file (SC Futures Order Routing (1-24-20) is saved?
DTS Config.jpg / V - Attached On 2020-01-29 22:37:21 UTC - Size: 131.67 KB - 337 views |
[2020-01-30 09:19:23] |
Sierra_Chart Engineering - Posts: 14189 |
This is in the Accounts.config file.
[2020-01-30 12:51:15] |
Can I copy the Accounts.config file to another computer and load the same data/trade service settings?
[2020-01-30 18:54:55] |
Yes.
[2020-01-31 19:53:15] |
I copied the Accounts.config file into SierraChart directory of my new laptop but I do not see the settings I saved called "SC Futures Order Routing (1-24-20)'. Any ideas how I can load the saved settings?
[2020-01-31 21:05:19] |
There should not be a problem with this. Make sure you copied that file when neither instance of Sierra Chart was running.
[2020-01-31 21:27:05] |
I copied the file again and still don't see the other saved configurations. Any other ideas?
[2020-02-29 18:28:51] |
Just following on this issue. I copied Accounts.config from my desktop to my laptop but I still do not see new settings on my laptop. Any ideas?
[2020-03-02 03:08:09] |
There definitively should not be a problem with this at all. This is very simple and straightforward. Just make sure you are copying the file to your laptop when Sierra Chart is not running on that laptop. And you are putting the file in the correct installation folder.
