Date/Time: Sat, 18 May 2024 15:57:06 +0000
Topstep Trader CLH0-NYMEX Intraday Chart Failure
View Count: 519
[2020-01-27 16:39:39] |
Ziklag - Posts: 73 |
As attached below, the daily chart (CLH0-NYMEX) runs properly but anything less - 4hr, 2hr, 1hr,30mins etc returns just today's data only [after I downgraded to v2036]
Date Time Of Last Edit: 2020-01-27 16:43:38
Private File Private File |
[2020-01-27 17:39:49] |
Sierra_Chart Engineering - Posts: 14423 |
When using Rithmic, you need to now be using service package 5 for Sierra Chart historical data access: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2036 Why there is a limitation with Rithmic historical data we do not know. To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
