Date/Time: Sat, 18 May 2024 12:47:38 +0000
Sierra Chart control bar
View Count: 526
[2020-01-27 07:49:30] |
User708302 - Posts: 6 |
Hi. I seem to have lost a button I liked on my Control Bar, pls see attached pic with it circled. Can you tell me exactly what it's called so I can add it again? Thanks.
Date Time Of Last Edit: 2020-01-27 09:03:44
sierra_button_marked.jpg / V - Attached On 2020-01-27 09:02:28 UTC - Size: 62.89 KB - 200 views Attachment Deleted. |
[2020-01-27 17:54:44] |
That button is the Tool Values Window. Refer to the following for how to add a button to the Control Bar. That particular item will be under the Window section: Control Bar: Customize Control Bars >> Control Bar 1-8 (Global Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
