Date/Time: Sat, 18 May 2024 12:26:57 +0000
Replay doesn't work
View Count: 605
[2020-01-26 17:52:47] |
User794190 - Posts: 26 |
I have been successfully using the replay feature for at least a year. No problems. I tried to use it today, and it doesn't work. It takes me back to the selected time and date - but stops immediately. Even the digital time display freezes. Last Friday, the 24th, I switched from Gain to Denali for my data feed -- which seems to work ok. Perhaps, the malfunctioning of the replay feature is related to the new data feed? Thanks for your help |
[2020-01-27 06:25:16] |
Sierra_Chart Engineering - Posts: 14423 |
Carefully follow the instructions here: Replaying Charts: Basic Chart Replay Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
