Date/Time: Mon, 29 Apr 2024 01:10:18 +0000
SIM mode
View Count: 626
[2020-01-24 23:25:37] |
User575399 - Posts: 305 |
Can I trade ES off SIM mode and trade crude on SIM mode at the same time?
[2020-01-24 23:39:51] |
Sierra_Chart Engineering - Posts: 14126 |
Yes, by using a sub instance of Sierra Chart, where the sub instance is set to simulation mode and the main instance is not. Refer to: Using DTC Server for Data and Trading in Another Sierra Chart Instance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-25 00:28:29] |
Can’t I just set one DOM to SIM and the other off SIM mode somehow ?
[2020-01-25 01:05:29] |
No.
