Date/Time: Sat, 05 Sep 2026 18:06:20 +0000
CTS T4 - Cannot download data lower than minute without timeout...
View Count: 1620
[2014-01-02 23:02:27]
esMike - Posts: 83
I am trying to download data lower than one minute on a low bandwidth connection and it always times out like this... I can download minute data fine, but more detailed than that... A heartbeat timeout occurs.
HD Request # 4 - Receiving Intraday data for ES.CME_20140300_ESH4.CME_Eq starting at 2013-12-09 18:00:00 | 2014-01-02 18:10:13
HD Request # 4 - Requesting historical Second data for ES.CME_20140300_ESH4.CME_Eq for 2013-12-11. | 2014-01-02 18:10:13
HD Request # 4 - Timestamp of first Intraday data file record written: 2013-12-11 17:14:52 | 2014-01-02 18:11:07
HD Request # 4 - Requesting historical Second data for ES.CME_20140300_ESH4.CME_Eq for 2013-12-12. | 2014-01-02 18:11:07
CTS Historical FIX Session: No heartbeat messages received from server. Sent Test Request message to server. | 2014-01-02 18:12:11
There was an error reading data from SSL socket. SSL error: 5 WinErr: 10053 | 2014-01-02 18:13:17
Socket receive error: Windows error code 10053: An established connection was aborted by the software in your host machine. | 2014-01-02 18:13:17
Socket closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2014-01-02 18:13:17
The SSL socket was shut down successfully. | 2014-01-02 18:13:17
CTS Historical FIX Session: Socket connection was closed without any logout messages sent or received. | 2014-01-02 18:13:17
CTS Historical FIX Session: Disconnected. | 2014-01-02 18:13:17
Date Time Of Last Edit: 2014-01-02 23:14:10
[2014-01-02 23:18:38]
esMike - Posts: 83
Here is a different variation that just occurred... I don't have this problem with DTN IQFeed or the Infinity Futures data feeds.
CTS Historical FIX Session: No heartbeat messages received from server. Sent Test Request message to server. | 2014-01-02 18:15:09
HD Request # 6 - Timestamp of first Intraday data file record written: 2013-12-11 17:14:59 | 2014-01-02 18:15:10
HD Request # 6 - Requesting historical Second data for ES.CME_20140300_ESH4.CME_Eq for 2013-12-12. | 2014-01-02 18:15:10
CTS Historical FIX Session: Disconnecting due to a loss of activity. No activity for at least 62 seconds. | 2014-01-02 18:16:19
CTS Historical FIX Session: Sending a Logout message. Text = No response received after Test Request. | 2014-01-02 18:16:19
The SSL socket was shut down successfully. | 2014-01-02 18:16:19
[2014-01-02 23:18:48]
We do have a solution, but the solution does cost a little extra. You can use the Sierra Chart market data feed:
http://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php
Otherwise, we don't know really what we can do about this. It's not something we have any control over.
[2014-01-02 23:46:00]
esMike - Posts: 83
Thanks. I might consider it. Minute historic data is fine for what I need.
[2014-01-02 23:52:17]
If you only need one minute historical data, then what you need to do is select Global Settings >> Data/Trade Service Settings >> Intraday Data Storage Time Unit >> 1 Minute.
After this disconnect from the data feed and then reconnect with the commands on the File menu and then re-download the data in the chart with Edit >> Delete All Data and Download.
For some background information, when you use our own data service, there is about a 4 to 5 minute timeout which is used on both the client and server-side to allow for communication problems. So it is very tolerant. It has been used now for nearly 10 years and works very well.
