Date/Time: Sun, 28 Apr 2024 16:36:53 +0000
Windows protect - blocks installing the EXE file
View Count: 538
[2020-01-16 12:35:12] |
User178540 - Posts: 15 |
Hello SC, I tried to run the sierrachart file downloaded EXE and got message from windows, see attached. it says unknown published. should I run this EXE? Thanks! |
windown siearrachart blocks.png / V - Attached On 2020-01-16 12:34:20 UTC - Size: 34.52 KB - 186 views Attachment Deleted. windown siearrachart blocks.png / V - Attached On 2020-01-16 12:34:44 UTC - Size: 34.52 KB - 168 views |
[2020-01-16 16:23:43] |
Use the "Run Anyway" option. Sierra Chart is safe. That message is expected based on security settings you have on Windows 10. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
