Date/Time: Thu, 02 May 2024 04:22:38 +0000
Chart Dom, bracket order
View Count: 1225
[2014-01-02 17:53:24] |
User025842 - Posts: 13 |
Hi guys, I don't understand how to make "Attached Orders" command to trade from Chart Dom, is this feature available at all? Thanks |
[2014-01-03 00:18:45] |
Each chart has its own Trade Window . You need to enable the Use Attached Orders option on the trade window. This is documented here: http://www.sierrachart.com/index.php?l=doc/doc_AttachedOrders.html#Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-03 18:02:32] |
Sierra Chart - Max - Posts: 5598 |
From user: Thank you for your replay,I fixed it. Can you tell me please how to to customise "Trade Orders and Positions",it doesn't give any date period span,may be b/c it is on sim mode? I tried everything ,and cannot figure out Thank you Sierra Chart Support |
[2014-01-05 09:20:06] |
Sounds like you are interested in the Trade Activity Log: http://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
