Date/Time: Thu, 02 May 2024 10:00:56 +0000
Spreadsheet trading not showing on the second chart
View Count: 585
[2020-01-15 17:21:49] |
sourdubber - Posts: 52 |
I opened a second chart using the Duplicate Active Chart option. Now I have two charts of the same symbol. Everything, including the studies, in the new chart appears as same as the first chart. However, I don't see any buy or sell signals that I see on the first chart. In the spreadsheet ("Sheet2"), all the formulas are the same but when I edit a cell (eg. K3), the lower cells don't update.
[2020-01-15 17:29:23] |
On closer examination, there are no formula values in "Sheet2". But the one that I renamed as "SecondChart" has identical values as sheet1 or "FirstChart". How would I link the chart to "SecondChart" and not "Sheet2"?
[2020-01-16 17:10:43] |
To begin with, refer to the information in Step 3 of the following documentation to be able to see orders from another chart: Chart Trading and the Chart DOM: Enabling Display of Orders and Trade Position, and Configuration of Orders and Trade Position Display Also, refer to the following to display Order Fills: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart With regards to the Spreadsheet, it does not sound like you want to have the spreadsheet fully duplicated and then creating an additional set of Buy/Sell signals, as this would just cause conflicts. Still, refer to the following for how to refer to sheets by name rather than number: Spreadsheet Study Inputs: Chart Data Output Specification Type And refer to the following for how to use a specific sheet for formulas, so you do not need to reproduce them: Spreadsheet Study Inputs: Formula Source Sheet Number Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
