Date/Time: Mon, 29 Apr 2024 07:05:08 +0000
order not fill
View Count: 483
[2020-01-15 15:07:25] |
User392279 - Posts: 67 |
When price go thru the order line it doesn't fill. not all symbols. I have seen it happened at NG and HG.
[2020-01-15 17:36:43] |
Is Trade >> Trade Simulation Mode On enabled?
[2020-02-04 16:50:09] |
no
[2020-02-04 20:09:42] |
This issue is not within the scope of our support. Can you tell us what symbol you are trading?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-04 20:10:18
