Date/Time: Wed, 08 May 2024 00:16:52 +0000
CBOE index data available during free trial, not available after I paid for Service Package 1
View Count: 1204
[2014-01-02 16:13:19] |
User41880 - Posts: 4 |
Do I need to go to Service Package 3? Shouldn't this be included in "Standard Features"?
[2014-01-02 17:42:13] |
What is the particular symbol you are having difficulty with? There are no symbol restrictions on package 1.
[2014-01-02 23:25:11] |
VIX, VXV, and VVIX. My tickers for stocks works fine. IB Gateway, IB API, and SC are all updated to the latest version.
screenshot.png / V - Attached On 2014-01-02 23:24:58 UTC - Size: 328.84 KB - 393 views |
[2014-01-03 00:13:55] |
You need to use the proper symbols. Update the Symbol Settings as explained here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings You will see these symbols now listed under the "Indexes" list in File >> Find Symbol. You will notice to symbol contains the security type and exchange. This is necessary. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
