Date/Time: Thu, 02 May 2024 22:07:58 +0000
Inverting an Indicator
View Count: 1009
[2020-01-14 21:31:49] |
User259545 - Posts: 24 |
Is there anyway to invert or display an indicator such as the ADX upside down? I would like to display the ADX in a chart region with the zero on top and the +100 on the bottom of the chart region. I've looked at scale and the other chart settings, but could not figure a way to do this. Any help you can give would be greatly appreciated and thanks for your time. Best Regards, Brett Walker |
[2020-01-14 21:46:55] |
Ackin - Posts: 1865 |
Study Subgraph Multiply Study Subgraph Multiply multiplier -1 in mind think axis + instead of - ;) |
[2020-01-15 02:02:11] |
I was able to invert the ADX study, but not correctly. I read the documentation for the Study Subgraph Multiply a couple of time, but still not sure quite how to use it correctly. I've included a screenshot and the chart file in a chart book so hopefully you might be able shed some light on the issue for me. I also want to mention that I am using an old chart build (1941), because with TransAct and builds after 1941 my charts have a serious lag when volatility hits the market. Thank you for you time and effort on my behalf. I really appreciate the help. Best Regards, Brett Walker |
Image 1.gif / V - Attached On 2020-01-15 01:33:59 UTC - Size: 151.75 KB - 280 views Chartbook2.Cht - Attached On 2020-01-15 01:37:39 UTC - Size: 877.75 KB - 228 views |
[2020-01-15 06:26:38] |
Try using "Study subgraph multiply" .... not "Study subgraphs multiply". There are two studies .... and differ only by one letter in the title. Look at attached image |
sub multi.png / V - Attached On 2020-01-15 06:24:33 UTC - Size: 55.95 KB - 255 views |
[2020-01-15 09:05:54] |
In the next release we will add a Study Subgraph Invert study. because with TransAct and builds after 1941 my charts have a serious lag when volatility hits the market. Very sad. We should not have bothered adopting the websocket connection.
