Date/Time: Sun, 05 May 2024 17:16:06 +0000
$NSHF not working
View Count: 1091
[2014-01-02 15:06:59] |
Handle - Posts: 36 |
Using Transact feed. The NYSE ADV/Decl Issues has stopped working. All else on my feeds is working fine.
[2014-01-02 16:26:53] |
This should now be resolved for you.
[2014-01-02 16:29:15] |
10-4 Thank you |
[2014-01-02 16:46:31] |
Please also update Sierra Chart before January 31, 2014. You can do this by selecting Help >> Download Current Version. Due to some changes, an update will be necessary by January 31. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
