Date/Time: Mon, 06 May 2024 02:59:40 +0000
quoteboard new high/low
View Count: 1412
[2014-01-02 14:58:02] |
User70302 - Posts: 30 |
have there been any changes with the quoteboard? I am running SC 1066 and I dont get any highlights for new high/lows anymore. update: it works, but only as long as I dont sort by Net Change %. please have a look at this. also, could you please consider to add an option to have the new high/low color highlighting done in the Last price column, instead of getting the highlights in the respective High and Low columns. Date Time Of Last Edit: 2014-01-02 15:14:10
[2014-01-03 01:52:56] |
We will look into the problem with high and low highlighting. There are no plans to add an option to color the last price column as requested. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-06 16:23:34] |
Al SC Developer - Posts: 434 |
This will be addressed in ver 1073
[2014-01-24 21:03:35] |
joshtrader - Posts: 439 |
As far as I can tell, this problem still exists in 1183.
[2014-01-27 10:08:06] |
Please describe again in your own words the problem you are having and if it is affected by whether you are using quote board sorting or not.
[2014-01-27 17:55:55] |
Without sorting, new highs and lows are highlighted. With sorting, they are not.
[2014-02-01 23:48:04] |
We will check on this.
[2014-02-03 06:20:49] |
This will be addressed in ver 1089
[2014-02-03 19:49:41] |
Thank you, I look forward to this-- a related question is, why is the foreground text color of the new high/low changed when the background is highlighted? For example, I have white text on a black background. When a new low trades, the background of the low turns to red. But it's hard to read the text because it changes to black. I would like the text to stay the same as it currently is, white. Is this possible? (see attached picture)
newlow.bmp - Attached On 2014-02-03 19:49:38 UTC - Size: 89.12 KB - 405 views |
[2014-02-05 15:20:09] |
In ver 1090, the foreground should stay the same.
