Date/Time: Mon, 29 Apr 2024 03:48:23 +0000
c_ACSILDepthBars->PriceToTickIndex() Returning Wrong Value
View Count: 485
[2020-01-12 21:24:12] |
User41727 - Posts: 124 |
Following situation: Last price for the bar was 4.78 at the bid. sc.BaseData[SC_LAST][sc.Index] contains 4.78. If I iterate through the depth data, then TickIndexToPrice() will return 4.78 for the index 478 as expected. However, if I either pass sc.BaseData[SC_LAST][sc.Index] directly to PriceToTickIndex() or assign the value to an intermediary float and pass that one, the function returns the wrong index 477. Whatever that function does, does not seem to be entirely correct for all argument values. Version: 2028 |
[2020-01-13 02:17:21] |
This must be some kind of floating-point error issue. Try adding .005 to the value before passing to PriceToTickIndex() .
[2020-01-13 15:35:10] |
That seems to work in this case, although I have not verified that it does not create issue elsewhere.
