Date/Time: Sun, 28 Apr 2024 23:24:54 +0000
Candle Pattern subgraphs... draw style doesnt change
View Count: 529
[2020-01-12 16:19:35] |
mtomas - Posts: 21 |
i have added 4 patterns to this indicator in settings. i try to choose a star, arrow, square, etc in the subgraphs draw style section for each of the patterns but it doesnt take when i press apply. Pattern 1 always stays to "Custom Text" even if display text is set to NO and I change it. Patterns 2-6 wont apply any changes... it just resets to 'ignore' once you press apply im on trial using the latest version |
[2020-01-14 00:36:15] |
That study does not support changing the subgraph. The only option available is on the Settings for the study for Use Numeric Value Instead of Letter Codes. Refer to the following: CandleStick Patterns Finder: Inputs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
