Date/Time: Sun, 28 Apr 2024 05:40:04 +0000
SC/TT Routing External Order Modification
View Count: 604
[2020-01-11 21:35:43] |
User379468 - Posts: 508 |
What is the cause behind this under 'Order Action Source' field in Trade Activity log? "Updating last modify Price and Quantity to current values due to an external modification or other reason" Log line attached. |
Private File |
[2020-01-13 17:51:40] |
We do not know because we do not have the full context. You need to follow this procedure: Trade Activity Log Analysis: Support Assisted Trade Activity Log Analysis This message is not anything to be concerned with though. It could be something as simple as a Target or Stop order being adjusted on the server side after the parent order fills. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-13 17:54:01
