Date/Time: Sun, 05 May 2024 19:04:47 +0000
how to change targets
View Count: 753
[2020-01-10 20:38:21] |
User921512 - Posts: 8 |
Hi - Can you help me figure out why I cannot change my targets after I place an order. It seems as though they are locked and I cannot figure out how to enable them. I have searched your website and still cannot figure it out. I've tried to drag the target by the line but can't and if I hit the X to cancel nothing happens. Thanks, Nik |
[2020-01-11 16:50:06] |
There should not be a problem with this. Make sure that Trade >> Chart Trade Mode On is enabled.
