Date/Time: Mon, 29 Apr 2024 00:39:35 +0000
Child orders and parent orders distinquition
View Count: 744
[2020-01-10 17:52:07] |
User460398 - Posts: 11 |
When Disabling "Use server side brackets Orders", you can make a color distinction between child and parent orders. To differentiate the ones that are sent to the broker and the ones that have not. Is it possible to have this color distinction if you have this option enabled? //which I def. want, this option Because I want to see which orders are active in the market and the ones which are depending on another leg (bracket orders) Couldn't find it in the settings. This would make my trading life a lot easier ;) cheers edit: it is distinction, no native english speaker :) Date Time Of Last Edit: 2020-01-10 17:56:46
[2020-01-25 03:49:12] |
Bumping my own topic.. Sorry, but I really want to know how to obtain this (thru setting)..
[2020-01-25 05:33:40] |
No, there is no color distinction available in this case. But you can tell based on the Status because they would have -Client in them if they are not. You can see this on orders displayed on a standard chart: Chart Trading and the Chart DOM: Viewing Orders and Trade Position on the Chart / Trade DOM And also in the Trade >> Trade Orders window. Look at the Status column. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
