Date/Time: Sat, 18 May 2024 07:14:33 +0000
Download of incorrect intraday volume data
View Count: 569
[2020-01-09 20:48:29] |
User804299 - Posts: 3 |
Hello, In this chart of KMPH the downloaded volume data from 15.30 till 17.25 today are incorrect. My data feed is Interactive Brokers. |
KMPH 5 Min #4 2020-01-09 20_41_20.312.png / V - Attached On 2020-01-09 20:42:43 UTC - Size: 25.97 KB - 216 views Attachment Deleted. |
[2020-01-09 21:17:44] |
Sierra Chart - Max - Posts: 5618 |
Please refer to the section Historical and Real-time Stock/Equities Data Volume Differences here: Interactive Brokers Trading Service: Historical and Real-time Stock/Equities Data Volume Differences Sierra Chart Support |
[2020-01-10 01:07:22] |
The above linked section is out of date. The volume downloaded for equities data from Interactive Brokers now has the specified multiplier from TWS applied. In newer versions the volume data will be actual instead of in hundreds.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-10 01:07:56
