Date/Time: Sat, 18 May 2024 10:21:44 +0000
Customized Control Bar presets for use in another version of SC
View Count: 488
[2020-01-08 18:28:20] |
User115050 - Posts: 2 |
Hi How do i transfer (make available) my customized Control Bar with all preset buttons/values to a different version of Sierra Chart? Thanks |
[2020-01-08 22:28:05] |
You would need to copy the file named Sierra3.cfg that is located in the top level of the Sierra Chart installation folder (typically C:/SierraChart). For further information refer to the following documentation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
