Date/Time: Thu, 16 May 2024 09:18:06 +0000
Commission
View Count: 945
[2020-01-07 15:15:04] |
User912405 - Posts: 14 |
I have a problem with the correct result display Although I entered the commission in Global, Symbol Settings, the result is displayed differently: - once without commission - once on commission What do I have to do to make sure that the result (as entered in the Settings icon) is displayed correctly. |
Attachment Deleted. |
[2020-01-07 15:54:22] |
The issue is not clear for us but if you want to see the commission value included with profit/loss calculations in a chart, then enable this setting for the chart: Chart Settings: Use Symbol Commission Setting in Trade List and Statistics Calculations (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-07 16:13:24] |
I have here the instrument M2KH20. For this I have entered a commission of 0.78 in Global Settings / Symbol settings. nevertheless I get different P/L - displays for the same trade and in the same chartbook. - once 11T (wrong, because the commission was not considered) - once 9Ts (correct because the commission was deducted correctly) |
[2020-01-07 19:09:44] |
Make sure the starting Date-Time of the Trades list is identical for both of those charts: Trade Activity Log: Understanding and Setting the Start Date-Time for a Trades List Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
