Date/Time: Wed, 08 May 2024 02:58:58 +0000
Location of custom studies that go with the program
View Count: 1275
[2014-01-01 15:28:35] |
User62923 - Posts: 27 |
In which file (with *.cpp extension as far as I understand) are the Custom Studies are stored that can be accessed through Studies/Add Custom Study dialogue? I'm specifically interested in the location of sourse code for jdt MACD/Bollinger Bands/Heiken-ashi, to make a very simple change there, thanks.
[2014-01-02 02:05:01] |
vegasfoster - Posts: 444 |
They are located in the UserContributedStudies.cpp file in the ACS_Source folder.
[2014-01-02 06:22:05] |
vegasfoster, thanks for the answer. But I only have a file with such name in the Data Folder and it has dll extension so I can't really open it through Analysis/Open(New) Custom Study File. I made a clean installation of SC to another location on another drive to copy it from - and the situation is the same, no cpp file. What's wrong? Can you please share the file? |
[2014-01-03 05:32:59] |
We do not provide the source code of the User Contributed Studies but you can search this Support Board and the old Support Board for them: https://www.sierrachart.com/supportboard/forumdisplay.php?f=94 We obtained the studies from these 2 Support Boards. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-03 07:14:15] |
Thank you, solved
[2014-01-03 20:59:01] |
Sorry, I guess I still have it from an old version, didn't realize newer versions didn't have it.
