Date/Time: Wed, 15 May 2024 05:36:30 +0000
Spread chart
View Count: 552
[2020-01-06 19:47:23] |
David A Jaeger - Posts: 1 |
Hi there, I would like to create a chart for the spread differential between the NQ v. YM. What formula would I use to create this chart? Thank you. David Jaeger |
[2020-01-07 19:31:48] |
You can do this with these two studies: Add Additional Symbol Study Subgraphs Subtract/Difference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
