Date/Time: Tue, 14 May 2024 13:34:06 +0000
Disable chart trading order confirmation via trade window not working
View Count: 1720
[2020-01-06 17:38:00] |
User912281 - Posts: 18 |
I have disabled order confirmation for all confirmation types under the Trade Window Menu, and saved the configuration. The setting works for trades executed via the Trade Window but not when modifying via the charts; still getting the order confirmation pop up when making changes to stops and targets. |
[2020-01-07 14:23:00] |
If you have made the change in the Trade Window and it is not affecting the chart, then that Trade Window was not the one for that chart. Refer to the following: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM Also refer to the following information to turn off notifications globally: Global Trade Settings Windows: Disable Order Confirmations - Global (Global Settings >> Chart Trade Settings >> General >> Confirmations) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
