Date/Time: Sat, 04 May 2024 00:59:13 +0000
[User Discussion] - Adding an option to a Study
View Count: 1046
[2014-01-01 14:22:18] |
fobglobal - Posts: 51 |
Hi: Could you add to the Moving Averages Study the Woodies EMA as another moving average type? It will be great. Thanks and happy new year |
[2014-01-01 19:36:00] |
No. You will need to create your own custom study to do what you want. Here is the documentation for this: http://www.sierrachart.com/index.php?l=doc/doc_CreatingDLLs.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
