Date/Time: Thu, 16 May 2024 11:55:20 +0000
Study button to recalculate all the same studies in chartbook
View Count: 543
[2020-01-06 13:14:38] |
User33743 - Posts: 83 |
Hello I build dll in which i use advanced custom study buttons to recalculate study on chart. Now i need to add control bar on every detached chart with button and click on every chart with this dll to get result. I would like to recalculate it by one click, but don't know how. Could you point out which function can help me with this? Best Regards |
[2020-01-07 19:16:38] |
As long as you know the Chart Numbers you can use this function to recalculate the charts: sc.RecalculateChart() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
