Date/Time: Wed, 15 May 2024 02:39:00 +0000
High/Low for Time Period Study Settings Changing
View Count: 539
[2020-01-06 03:42:56] |
User379468 - Posts: 508 |
I have one saved instance of the 'High/Low for Time Period' study in my saved chartbooks where the time settings change/get lost for some reason, possibly on updating to a new version of SC as I just did to v2028. My SC folder is also synced across several systems. Can't figure out why it keeps happening periodically and needs to be fixed consistently then across all charts on this specific saved instance of the study only, seems inconsistent, but I don't understand why the setting could ever change. Any idea and how to prevent? Also, I have not posted here in months, and then it was a couple posts, can you remove this? "Your account recently has exceeded the number of allowed support requests. Support for your account may be limited. Use support only when absolutely necessary." Date Time Of Last Edit: 2020-01-06 05:20:32
[2020-01-06 23:10:30] |
It does sound like the issue is related to this: My SC folder is also synced across several systems.
If there is a change with Study Inputs in one particular version, once you update the Inputs and you save the Chartbook that is no longer going to be an issue going forward. And almost always we have special update code, to ensure the Inputs are automatically updated appropriately. The support notice will automatically clear over time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-06 23:10:50
