Date/Time: Tue, 14 May 2024 23:09:01 +0000
Custom Indicator values from external Source
View Count: 911
[2020-01-05 19:51:36] |
Crunch007 - Posts: 2 |
Hi, I'm new to Sierra and I'm trying to find a way to integrate my own Indicators. Since I am not very familiar with C++, I am looking for an easy way to use my already centrally calculated data as an indicator. I can provide the file arbitrarily, but I am looking for an easy way to use it in Sierra. A possibility would be a JSON file which contains only BarTimestamp and Value to paint the indicator based on that information. Are there already finished studies that can handled external, manipulable files. Or are there alternative possibilities for implementation? Thanks in advance. |
[2020-01-06 01:34:05] |
Refer to this page and see if this helps: Text/CSV Data Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-06 17:01:14] |
Programming_autotrading_phonesup - Posts: 59 |
If you still need more help please send me a Direct Message.
[2020-01-06 20:59:34] |
I will give it a try and get back to you in case of problems. Thanks for support |
